    Results 1 to 7 of 7
      Kiler wisconson
      Need Head Gasket Help!!
      I want to add head gaskets to lower the compression on my SBC..
      I am only running stock gaskets right now with PRO1 aluminum heads..
      Current compression is 10.25 Im using Flat top pistons and have a ZERO deck hight!
      Im looking for 9-9.50 as a final compression ratio!
      HOW THICK AND WHAT KIND OF GASKETS SHOULD I USE?
      Thanks..
      Brian
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
