    Results 1 to 9 of 9
      Jun 2006
      hou, tx
      rear shocks--relocate or not
      Will doing a rear shock relocating mod allow any more room for a wider tire IF NOT tubbing the car?
      I have read that 9 1/2'' is the widest tire that will fit in stock form but will moving the shocks inbord gain anything? maybe 10''?
      I will be using 17'' wheels.
      Billy
      '69Maro...LS1,4L60e, --motor's done, 7/07--
      now to upgrade the suspension before someone gets hurt!!
      Den Helder, the Netherlands
      Country Flag: Netherlands
      No, moving the shocks will not help you. The inner wheeltubs are the limiting factor.
      I have 17x10 on my car and what I did to make them fit is, what I call a micro tub. Just remove or cut the small section between the inner wheeltub and the frame, hammer the innerwheeltub as much in as possible and weld the seam. It gives about 1 to 1-1/2" extra room.
      Obviously the BS of the wheels is also very important, plus all these cars slightly differ from one to the other (mine even has a difference between the right and the left side) so you'll have to measure to make sure you'll be OK.
      Jun 2006
      hou, tx
      Sounds like a good mod, do ya have any
      thanks, billy
      Jun 2006
      hou, tx
      Can someone with a rear shock relocation on a 1st gen camaro tell me what rear shock you are using.
      and pictures of your rear shock relocation would be great !
      just trying to get ideas on which shocks/kit to use. or maybe just fab my own.
      Billy
      With a 17x10 wheel you don't have to relocate the shock (or at least not in my case).
      Jun 2006
      hou, tx
      yes, I got ya. but I am using (right and left) LS1 rear cailpers. trying to not do the inverted left caliper mount mod.
      Just kicking around ideas...
      billy
      Sep 2007
      Do you have any pics. What is your backspacing and what size tire do you run?
      Quote Originally Posted by neki67
      I'm running 285/40-17 in the rear.
      I'll have to see if I can make a couple of decent pics of what I'm referring to.
