      Florida
      4l80e to crate ls2 questions
      I have my car setup to run a lsx motor and a 4l80e trans right now. I already have the trans and will be ordering a crate ls2 in the very near future. My question is will the 80e converter bolt right up to the flywheel that is provided with the crate ls2?
      I also am wondering what to do about a converter. I am going to be putting a nice cam in the motor and maybe some mild head work to the stock heads. My 9 inch has 370 gears. What would be suggested for a converter? I plan to take this car on the power tour when its ready so it needs to be tame enough to pull some good miles on the hwy.
      Jun 2005
      Omaha, NE
      Give Steve a call at Twist Machine. He can spec out a converter for you, and he is the man for automatics!
      Jeff
      Aug 2001
      Wilton, CA. (Sacramento)
      I'm running the same combo. I ran the stock LS flywheel with a GM adapter that allows the 4L80E converter to reach the crank index hole for the nose. It's basically a spacer with longer bolts; otherwise the converter nose will not reach the crank recess.
      You can also use a custom converter that has the extended nose to reach the crank, and may be the way to go if you don't have a converter yet. I already had mine, so I used the adapter.
      Jody
