Thread: King Pin Inclination Help?
10-04-2007 #1
I'm hoping some one on here can help me with this...
I'm working on a car that has less documentation then anything I have ever worked on, and to be honest it has turned into a VERY bad basket case. Never the less, I like it, and I'm going to finish it one way or the other.
Basically I have to get a SHO Spindle on a lower control arm of a Ford Festiva... I have talked to the original builder of this car, and he has been an inspiration to say he least... He is a Super nice guy, and is a wealth of knowledge, but he is very busy, so I hate to bug him with every problem I have on this car...
Well here is my problem. I just found out about two days ago that the spindles to the SHO were milled where they accept the struts to reduce the Inclination of the king pin... This was done because the car was a FWD car, and now it's going to be RWD, he said he recalls from ~ 1991 or so that the original FWD set up was about 13 Deg. and you need to reduce it to about 8-9 Deg.
So here I am scratching my head wondering about this problem..
Will this be effected by the offset of my wheels?
Do the numbers of 8-9 Deg. make sense?
Can a set of caster camber plates help this?
Is there a better way? Not so much with the SHO spindle and the king pin problem but the set up of the tube in the Spindle that holds the Koni insert? This just seams bulky? Is there a strut that can just get clamped to the spindle, or is the steal tube the best way to reduce the flexing?
This car was setup about 17 years ago, and I just want to modernize what I can, some of it must stay to keep it similar to the original setup, but I'm open for improvments.... The car will be driven on the street about 98% of the time, and maybe some track day fun.
What I do know about this spindle swap is they used a spacer of sorts to join the lower ball joint of the Festi ( a one piece unit with the control arm) with the hole in the spindle... They also used a spacer to joint the SHO out tie rod to the inner tie rod of the Festiva.. I'm going to change this in favor of a custom inner tie rod that will directly hook to the SHO outer unit.
Thanks for the help in advance!
Brian
93 Mustang LX Coupe 347 S Trim Vortech
92 Ford Ranger XLT 331 T Trim Vortech
91 Ford Shogun Nothing Yet!
