    Results 1 to 9 of 9
      Sterling Heights
      Where to purchase Mini Tubs
      Is DSE the only place to purchase Mini Tubs for a 69 Camaro? I did a quick search on here and didn't see anything. Most people seem to be making theirs. My body shop wanted to purchase the deep tubs.
      I just thought $400 for a set was a bit much. Maybe not. But the
      outers can be bought for about $85.
      May 2002
      Northern California
      Before DSE we just added a section of material to the existing wheel house. That added 4 hours labor to the job. After labor and material $400 isn't too bad.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Apr 2004
      OKC, OK
      DSE is the only one making them and like Vince said, by the time you figure cost of widening a factory tub, DSE tubs become very reasonable unless you are capable of doing the work yourself.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Flo-rida
      How about some universal tubs from jegs? I thought about buying some of those and well not exactly tubbing the rear but adding more to the factory wells.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      San Jose, CA
      Quote Originally Posted by Project69
      It all depends on what you want your finished product to look like. I've seen some really nasty mini-tub and full-tub HACK jobs. If you ever plan on selling your car, a hack job might lower the value of your build.
      Also, if you are considering using racing tubs on the street...consider using steel instead of aluminum for durability.
      May the Force be with you,
      Tony Huntimer
      http://www.goodies-speedshop.com/
      @Camaro.Family Camaros
      1986 #IROCdaily - Stock IROC
      May 2002
      Northern California
      you could but it would be a waste, try a metal fabrication shop and ask for a 5" strip of 16ga mild and have then roll a 25" radius to it. Most shops will do it for real cheap. Total cost at my shop is $40
      Flo-rida
      Quote Originally Posted by MrQuick
      Good idea. But i cant find any local shops that do that. Unless someone knows one around Lee county area?
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      May 2002
      Northern California
      how about your local metal supplier?
      Jul 2004
      Baytown, Tx
      These are what I went with in my fastback. I do not think you can beat them on price.
      http://www.suicidedoors.com/RoundWheelTubs.php
