      Near Dayton, OH
      Currie-trac rear control arms
      Are these able to be disassembled? I assume they are are since the spherical bearing at one end is held in by a snap ring. What about the polyurethane bushings at the other end?
      I bought these new and installed them in my '87 but finish on them is terrible. I don't know what paint they use but it doen't hold up well at all. You can just about hit it with your figernail and get it to chip.
      So I wanted to blast them and coat them with some high gloss black powder coat.
      1987 Olds Cutlass Supreme FE3X Clone
      EFI455/T56/9" w/ 4.30 gears
      __________________________________________________ __
      PA.
      Yes they can be disassembled. Take the snap ring out and press the Johnny Joint out. Make sure you don`t loose the thrust shims if there are any in there. You can do it with improvides tools or Currie sells a press for them. The rear come apart like any other polygraphite bushings. Take the sleeve out of the center then use a drift to push the bushings out each side. The finish in the Currectracs is blackpowder coat. Normally it`s very chip resistant and wears like iron. We stripped the finish off a set here to custom paint them and it was genuine pain to get off. Sounds like someone at the powder coater was having a bad day when they did yours... Mark SC&C
      Near Dayton, OH
      Thanks Marcus.
      I can tell these aren't even powder coat. Just standard paint thats peeling off everywhere. Not to mention they were just thrown in a box when I received them with no packing material. I probably received a pair of rejects.
      They installed okay other than being an extremely tight fit in the frame and rear end. I just need to pull them back out and have them powder coated.
      Thanks for the help!
      Quote Originally Posted by Marcus SC&C
      Yes they can be disassembled. The finish in the Currectracs is blackpowder coat. Normally it`s very chip resistant and wears like iron. We stripped the finish off a set here to custom paint them and it was genuine pain to get off. Sounds like someone at the powder coater was having a bad day when they did yours... Mark SC&C
      Oct 2006
      Chicago
      I'd complain to Currie if they've never been installed... those are some pricey arms to be doing that...
      Luke
      '63 Chevy II wagon - project
      Dallas TX
      Must be a fluke. Mine came in and looks like what seems to be nice quality semi-gloss black powder coat.
