    Results 1 to 15 of 15
      Dallas, Texas
      Camcojb- Is there a thread with details on your TT build?
      The orange car you are currently building, I see the pics on your website, but wanted some more details on the car/build itself, do you have a thread here listing the details already? If not, do you mind giving some? My next project will be very similiar, just wondering....thanks and car looks great
      Aug 2001
      Wilton, CA. (Sacramento)
      I will be upgrading the site a bunch in the next week or so, but my shopping list is mostly done if you want to know what parts I'm using. Let me know, glad to help.
      Jody
      Dallas, Texas
      thanks....
      what rear tires you running? size wheels?
      what rear modifications did you do to fit them?
      Hit any snags?
      What rear suspension are you running?
      Did you use an aftermarket front clip to run bigger meats up front? If so, what?
      What tranny are you going to run?
      Aug 2001
      Quote Originally Posted by ZX10R
      thanks....
      335/30-18 Michelins with 18X12" Fikse wheels (6.75" b.s.)
      DSE mini-tub, and a narrowed rear end...56.687" flange to flange
      Hit any snags?
      yes, one of my wheel tubs was 1" narrower than the other side and the wheel/tire wouldn't fit. Replaced the 1/4's with nos pieces and problem solved!
      I'm using DSE 3" dropped springs and their Koni valved shocks. Del-a-lum bushings at one end of the springs. Currie rear with aluminum center section, nodular third member with tru trac diff.
      No went the DSE way again with their a-arms, and coil over kit with Koni shocks, their valving. Also DSE bushings and a hollow Hotchkiss 1 1/8" front sway bar
      T56, prepped a la Mule
      After talking to Kyle at length and knowing that he and Stielow have gone very fast on tracks with a fairly simple combo of parts like mine, I figured it would be just fine for me.
      Jody
      Mar 2003
      Fallston, MD
      Trany
      Are you going to get the fancy Vanquish gears like Charley did.
      Brian
      Aug 2001
      Quote Originally Posted by B Schein
      Brian
      Lost you on that one! Had to get ahold of Charley. He reminded me of the gear change Mark made. I'm waiting on info from Mark this evening, and then I'll know more.
      Jody
      Sep 2001
      Rochester, Minnesota
      Shopping almost done? Hmmmm....
      Scott
      Twin Turbo 434 SBC, T56, Baer brakes, HRE wheels, etc...
      My 69 Camaro
      Lateral-g.net
      Mar 2003
      Fallston, MD
      I am preaty sure Charley told me that the fith/sixth gear set was From an Aston Martin Vanquish or whatever Aston Martin uses the t56.
      Aug 2001
      Scott,
      I've got more bought than what's left to buy, if that means anything! I've got all the big ticket items here, but you know how the small stuff will eat you up.
      Jody
      Aug 2001
      I am preaty sure Charlie told me that the fith/sixth gear set was From an Aston Martin Vanquish or whatever Aston Martin uses the t56.
      You are correct. Fifth and sixth use different gears than normal with much less drop between gears. I will probably opt for the same. Got the info from Mark Stielow through Charley tonight so I'll be sending my T56 out for mods.
      Jody
      Mar 2003
      Fallston, MD
      Are you get all the other parts they put into the mules trany I Thought Charley said some of them were still prototypes that were still in testing. What ever Mark has done with that transmition is truly impressive to hold up to the power that the mule now produces with its new motor.
      Aug 2001
      I'm gonna try! Mark didn't think there was an issue with getting mine modded the same, or at least didn't say there was.
      Jody
      Sep 2001
      Well, Jody, you know where I'm going. lol
      G-Force Transmissions will do that for you. Of course, it isn't cheap by any means.
      http://www.g-forcetransmissions.com/tran_gt-56.asp
      Scott
      My 69 Camaro
      Lateral-g.net
      Aug 2001
      My 2004R guru just told me about a manual trans guy here in town I'm going to talk to first. Mark used D&D for his mods, so I'll be making some calls to decide which way to go.
      Thanks Scott!
      Jody
      Dallas, Texas
      PM sent Camcojb
