    Thread: QA1 bounce
      Jul 2007
      QA1 bounce
      Hi,
      I recently bought a 69 Firebird which had QA1's all around. The A-Arm bushings were shot, so I decided to replace. After pulling both front QA1's out, I noticed the R shock was adjusted at least 1-2cm lower than the left. I replaced the bushings, then readjusted the shocks side-by-side to exactly the same amount of threads on the coilovers. After installing I noticed the R side is now 1/2" lower than the L...???!! I adjusted all the shocks to 5+ clicks from zero. Took it for a test drive which felt ok....except that it felt like I was bouncing up and down over 40-50 MPH. Did I do something wrong?? Do the QA1's act this way??
      IL/TN
      what length are the rear shocks? most shocks made for 1 st gen F-bodies are too short on 69 firebirds over the years the lower rear leaf spring plates may have been changed and the wrong one used, mono leaf VS multi leaf, what happens is the shock over extends that's one place to look.
      https://www.protouringf-body.com "doing what they say can't be done"
      Aug 2001
      Connecticut
      I noticed that they are a bit bouncy in the rear over +4 clicks, but I'm on coilovers on all 4 corners, so it's not exactly the same I guess. If the shock lengths are ok, You might want to try them at +2.
      (at +7 it was so bouncy I could burn the tires in 3rd gear)
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Jul 2007
      I lowered the clicks to 3...and the bouncyness subsided!
      I personally feel these shocks are junk though. When I lowered to 3 clicks I noticed a bunch of shock oil! I cleaned and drove again...same result. They look like they couldn't be more than a year or two old! They have no dust cover, thus dirt simply sits on top allowing dirt to slide along piston.
      I know some swear by them...I don't
