    Results 1 to 10 of 10
      Sep 2007
      How to make these pipes?
      Could someone recommend a method of making these pipes? They're 1-1/4" OD aluminum pipe (1-1/8" ID). I would like them to be a single piece; not cut and welded.
      Matt
      Eastern Virginia
      What are they for?
      Scot
      86 Monte SS
      Sep 2007
      Cooling system in a vehicle.
      Sure ... get a structural tubing bender, and the right mandrels. If you are making them from aluminum tube, be sure they are fully annealed. The tube lips on the end can be rolled with a tube bead roller.
      jp
      ​John Parsons
      Sep 2007
      Is that something I can purchase for less than $1000?
      May 2002
      Northern California
      doubtful, I don't think the pack with sand trick will work either.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Maybe ... but mine cost $2200 with a pair of mandrels.
      ​John Parsons
      Sep 2007
      So there's no way these pipes could be made with a rotary draw bender, like the model 3, for example?
      Houston Texas
      Yes you can do them with the model 3 and for less than a thousand dollars. The only problem you might run into is the bends being close together on the one piece but it shouldn't be a problem.
      Where do you live? i have the jd2 model 3 and a 1 1/4" die you can use if you are close.
      68 Camaro - never to be finished
      06 Silverado - Forged 370, L92 Heads, big cam, 4l80e ect. eventual donor for the above
      http://www.youtube.com/watch?v=KmB2y7uX38I
      Boonville, Missouri
      We use a conduit bender - Contact a local industrial electrical contractor.
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
