Results 1 to 20 of 21
Starting The Transformation
- Feb 2007
- 327
Ineresting pic. Where I work we have one of those things which you point at something ant it will give you the surface temperature of whatever you point it at. I'm curious about tuning a motor this way too. What kind of engine is this? Is it carbed, throttle body injection or is each cylinder injected? You should have tried to take a picture of the other side about the same time.
Do you have the radiator filled all the way? Maybe there is an air pocket in the front of the motor since they are usually tilted up a little. If your radiator isn't filled all the way maybe that would cause it. I can't remember but I have a book called "how to tune and modify engine management systems" I think it actually does say what a exhaust temperature baseline should be. I'll see if I can find it.
