    Results 1 to 20 of 28
      Sep 2007
      Power steering too easy!
      67 Camaro, originally a 6 cylinder with power steering. After engine swap (454) steering became super easy. You can actually turn wheel with your pinky. Still using the 6 cyl. box but changed to a V8 pump. Would like to fix situation. Would also like to eventually switch to a quick ratio box. I'm looking for recommendations on fixing the current problem as well as possible quick ratio box swap and the potential problems (header clearance, etc.)
      research changing the caster.... more caster will change that sensation.
      when you put the new motor in, did the extra weight drop the front end some? if you change the rake where the front end goes down, positive caster approaches more vertical which will make steering easier.
      did you get an alignment after the swap?
      Another solution to increase steering effort if an alignment does not help is to enlarge very SLIGHTLY the hole in the back of the orifice that screws into the power steering pump high pressure side outlet or change the orifice with one from another PS pump with a larger pressure outlet hole. The easy way to measure the hole of the orifice is with a drill bit. We are talking a very slight increase in orifice diameter if you choose to drill your current orifice will increase the steering effort required to move the steering wheel. This increase in orifice diamter will reduce the high side line pressure to the steering box and thus reduce the amount of power assist provided by the steering box therefore increasing the effort needed to turn the steering wheel.
      This is the "poor man's method" to change the amount of power assist provided by your PS system. Don't laugh, it works!
      Mike
      www.musclecardeals.com
      Sep 2007
      The car has been re-aligned since the motor swap. There is actually extra caster because the car is partially set-up for drag racing. I forgot to mention that I even have a Grant steering wheel which is considerably smaller than the stock wheel, this should actually make it harder to steer. I do believe it is a pressure problem because the power steering fluid very slightly seeps out of the cap as if it is foaming. Any thoughts about the box or why my combo is actually doing this?
      May 2006
      I have the same problem look at this tread. You can put a late model steering box in.
      https://www.pro-touring.com/forum/sh...ad.php?t=34260
      Huntington Beach, CA
      I've read that there is a valve in the steering box that effects effort and can be adjusted but have no idea how or if true.
      Central CA USA
      Quote Originally Posted by vintageracer
      My apologies to Vintageracer, but...
      I don't agree with the above statement at all.
      The orifice drill-out method is to increase system flow, not to increase effort. If you have trouble with the pump not "keeping up" then drilling will make the steering more responsive for autocrossing or racing, but tends to make the steering box more "nervous" acting at low speeds, especially if you go too far. I drilled mine out all the way long ago and it fixed the slow response time for autocross, but I later found out I didn't have to go so large. More flow equals more heat.
      You could mess around trying to reduce pressure in the pump, but in the end you really want a late model box with high effort built-in. The torsion rod in the top of the box is stiffer allowing more effort before the valve is opened.
      You can help driveability by increasing caster to as much positive as you can achieve, usually around +3 degrees, set .5 deg neg camber, set toe-in at 1/16".
      We did this to my wife's 68 Camaro and it is much more steady on the road, even though it has a stock box.
      Also take up any extra lash in the box by setting the steering straight ahead then turning the adjuster screw down until some resistance is felt. You want to take up lash without adding extra pre-load to the box, so don't over do it.
      David
      the same problem in my wifes olds omega.
      i install a steering-shock from MOOG and its great ! not to hard, but from the steering comes a good feedback
      greets
      Klaus
      May 2000
      Get an ATS box.
      Nov 2004
      Colorado
      Quote Originally Posted by David Pozzi
      David
      If you increase flow, don't you reduce pressure?
      Ocean View, Delaware 19970
      Flaming River 14-1 ratio. Had to shave a little of the mounting boss on the box. About 1/8'' clearence from header. I actually feel like I have control of car now.
      69 RS Rat. Ocean View, De. 19970 If you wake up and you can put your feet on the floor, IT'S A GOOD DAY!!!
      Sep 2007
      Thanks guys, I'll look into all your suggestions.
      Southern Indiana
      Well as for more positive caster making the steering feel tighter, uh no.
      Been doing Alingments for the last 20 yrs and more positive caster will make the steering easier to turn but will allow the wheel to return much better.
      As for the feel ,its in the box. I agree with one thing there is a fella who builds boxes, Lee is either his name or the name of the company.
      As for specs give any car as much pos caster as you can, but leave an extra .5 degree on the right to compensate for the road crown.
      Use as much negative camber (providing your suspension is setup already optimized for handling) as you can with out destroying your tires and the max that makes you fast but not out of control.
      At autocrosses a friend of mine uses his Hitman aligning tool to give his car a set amount of toe out to optimize his turn in. Chews a **** load off the tires but makes his car handle great.
      But he has to retoe in the car of it would really eat the tires off.
      I have found that toein has to get moved around after installing new ,wider tires and wheels, changing weight and and such but I try to stick with the total max and min from stock specs.
      Rarely a car fudges from the stock specs you may just have to use more or less dependent upon the other mods.
      Now if you have changed a lot of parts (mainly control arms and subframes, but not spindles or tall ball joints) ask lots of questions and the designed in alignment specs they recommend.
      Just some insight from my experiences.
      But for my choice I would step up the gear box first.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Central CA USA
      Quote Originally Posted by EFI69Cam
      Not on a Saginaw pump, flow is controled by the orifice size and the tiny side bleed where the orifice section expands suddenly. This causes movement of the spool shaped valve just in from the outlet fitting. Movement of the flow valve uncovers the return port recycling the oil flow inside the pump.
      The pressure is controled by the steel ball and spring inside the "spool" valve.
      David
      Central CA USA
      I wonder what changed between the 6 and the big block?
      With more engine weight, the car would sit lower and it would probably gain neg camber, with the front lower than the rear, some positive caster would disappear. Did you have the car re-aligned after the engine install?
      Anything else different?
      David
      Sep 2007
      Dave,
      Yes car was re-aligned after swap. 3 degrees positive caster, 1/4 negative camber, 1/16" toe. Besides the engine a new pump was installed. Definetly feel it is a pressure problem, not alignment. No exageration when I say you can turn the wheel with your pinky (this is while in park), when driving a cross breeze through the window probably could steer the car if I was not holding on to the wheel. My set-up would actually be perfect for those guys with trucks and oversized tires.
      ED
      Sep 2007
      69 Bbird,
      I looked at the past post, what did you decide to do in the end???
      ED
      Quote Originally Posted by MonzaRacer
      Been doing Alingments for the last 20 yrs and more positive caster will make the steering easier to turn but will allow the wheel to return much better....
      sarcasm aside, i think it's important to distinguish low speed steering effort & high speed steering effort. i agree with Lee that additional caster will not noticably increase steering effort, but that's only true at high speeds. at low speeds, or parking lot, it certainly increases effort. when you said 'steer with your pinky' i ASSumed it was low speeds. (dangit.... i inserted sarcasm... ). i would also think that pump/box setup has a bigger effect on effort than alignment. the fact that you swapped pump, i think you're on the right track.
      take a look at Chip Woyner for getting your box rebuilt: http://www.powersteering.com/
      Nov 2004
      Colorado
      David
      Thanks for the clarification.
