Results 1 to 9 of 9
Thread: Camber Curves, caster numbers
- Aug 2007
- 16
I have posted in here a few times looking for setup advice and I feel I have narrowed my search for a new front suspension set up for my 1st gen f body. Im torn between the DSE speed kit 3 or the ATS Chicane Lm kit with afx spindles. It seems that both are going to get the improved caster through the a-arms correct? Both are to improve bumbsteer, so it seems the last of the big problems to fix is the camber curve. Form what I gather the DSE uses a partial(not as drastic of a move) g-mod to improve the camber curve. Ats uses the spindles. With a cost of the ats being $1000 does the ats improve the camber curve that much over the DSE. Or woould the benefit be just that the ATS now allows me to run better brakes. The other option would be to go DSE and order stock ats spindles and still be about $400 ahead. So basically I am looking for cold hard numbers on the geometry anyone know how much better the ATS kit is over the DSE kit? I ran a search and didnt find anything in the way of numbers.
