      NW Oregon
      295-325 / 40 series/ 19's????
      I can only find Goodyear f1 supercars in a size like this....what's the deal with that?? it's only a 28in or so tire
      Oregon
      You can get Hoosier comp slicks in 315/40ZR19...otherwise options are limited. There are very few OE cars running that high of a profile tire/wheel combination, hence the scarcity.
      If you don't need that large of a diameter, you've got a lot more options in the 30 series (same as C6 Vettes and others) rubber...although several are runflats.
      Jan 2007
      Sarasota, FL
      The closest I have seen are the Pirelli PZero Corsa System tires at
      345/35/19.
      So. Cal
      bridgestone also makes the scuderia in the 345/35 19 which gives you about the same overall diameter you are looking for, just a tad wider.
      NW Oregon
      I saw the 335-345's just cant fit that wide. thanks fellas
      florida
      ive got 295 35 19 bf goodrich kdw 2s
