Results 1 to 10 of 10
Thread: Front sway bar for 69 Camaro
09-04-2007 #1
- Aug 2007
- CT
- 799
I was wondering what you guys are runniing for swaybars on your first gens??
It is a basiclly stock front end with DSE 2" drop springs and their shocks..
The car will has an LS1 if that matters..
09-04-2007 #2Myself and most guys around here run the Hotchkis 1 1/8" hollow sway bar, part #2207-F.
http://store.summitracing.com/partde...5&autoview=sku
JKJeff K.
69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
09-04-2007 #3
- Aug 2007
- CT
- 799
How hard is it to install this unit??
Do you need to modify anything or is it direct bolt on??
09-04-2007 #4It was a direct bolt on for me. maybe took a half hour. It's a little bit easier to install if you have the rest of the suspension apart doing a rebuild like I did but that's not necessary. You can get it in there according to hotchkis' instructions with a little turning/twisting, etc in about an hour, two at most. You might scratch it up a little bit in the process, but if you're worried about it you could wrap it in painters tape.
Jeff K.
09-04-2007 #5
- Aug 2007
- CT
- 799
jknight,
Thanks for all the great info!! I will be ordering it today or tomorrow..
Do you run a rear sway bar?? If so any info on that??
The car has DSE MiniTubs, will that effect anything??
09-04-2007 #6No problem skeeter, glad to help.I don't think you'll have any problems with the mini-tub, though, don't think it makes a difference.
I don't currently run a rear sway bar, since i really don't think its necessary for how I intend to use the car (street w/ occasional autocross). I'm by no means an authority on the merits of using a rear sway bar though. But I'm sure some other guys can chime in here or you would probably be well served to do a search for rear sway bar. I know it has been discussed in great detail in the past.Jeff K.
09-04-2007 #7
- Aug 2007
- CT
- 799
cool thanks again..
10-02-2007 #8
