    Results 1 to 11 of 11
      northern california
      can fender be saved
      Attachment 18785
      Attachment 18786 thinking of buying this fender for my 65 chevelle can it be saved?
      San Jose, CA
      Without being an owner of a Chevelle it's REALLY hard to tell what part of the fender that is. Is that a high-stress area? Or is it a headlight bucket trim hole?
      I'm no body guy, but if you find all the fractures you can drill the end of them to keep them from traveling further. Then weld everything together. I wonder if you can weld a washer to the backside to further strengthen the hole...but if you can find a better fender and have the dough, get a better one and save some time.
      Good luck,
      Tony Huntimer
      RaceHome.com
      @Camaro.Family Camaros
      1986 #IROCdaily - Stock IROC
      Oct 2005
      Ferndale, WA
      not sure what parts were looking at as well. I'm guessing a wheelwell bolt hole on a fender and I'm not sure what the other one is. If there is no other major damage, that thing can be saved for sure. Just clean-strip the area around the crack and weld her up. I like the idea of the washer welded to the backside though.
      72 Chevelle Done!
      67' Hell Camino- Under the knife
      Some day: Porsche GT3/ C6R inspired 69
      NY
      Looks like a fender/ inner fender to me. It can be saved. Drill a hole at the end of the crack like Tony said, AND make sure you get the two sides of the crack flush with each other (don't lap it) before it gets welded.
      The needs of the many outweigh the needs of the few.
      northern california
      sorry for the bad pics thats what the guy sent me. crack is on head light trime hole on drivers fender.is this some thing you guys see alot on old sheet metal? whould you guys put this on a car you where building?these fenders for 65s are hard to find.thanks for your continued help on my build.
      NY
      You have to work with what you can get. If you feel you are capable of fixing these parts now, get them. Otherwise, you have to wait who knows how long for better fenders. And that is if any are out there.
      northern california
      thanks i will by fender and fix it my self . also what size hole should i drill
      NY
      no bigger than 1/8".
      northern california
      i go the fender today lookes good as soon as i weld it i will post picks .thank you for your help and your time.
      NY
      Not a problem, that's why we're supposed to be here.
      livermore ca
      mine is the same on my 65 iam doing the same dill a small hole get a hammer and doller work it were it needs to be weld it and then did what little glazing needs to be done
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
