Results 41 to 51 of 51
Thread: Sub-frame from ECKLERS
08-26-2007 #41
FWIW, if Scotts does not have any computer programs to map out the alignment changes due to suspension travel and then give a printout, then they could do it the old fasioned way.
Using standard alignment equipment you can record the numbers at different heights. Just set the alignment at "standard" ride height, give the specs, and then give the specs of where the tires are pointing every inch of travel from that height. Caster, camber and toe.
I understand that the "on paper" specs might not tell us exactly how the car will handle, but it should be a good starting point.
I'm thinking that this info is something that any subframe manufacturer should be able to show for their product. Am I correct in this assumption?
