    Results 1 to 14 of 14
      Aug 2006
      Best Suspension mock up practice?!
      Im looking into putting C5 suspension in my 68 camaro. I was wondering how you guys or best practice to mock up the stock geometry of a car? Ive seen mouting the hubs to a stand to get the right height and what not but what is the best to mock up the arm locations? I have access to a C5 vette so I can get the measurements do they just make brackets for the control arms? I understand taht the track widths are different and wheels back but im trying to determine how to mock the arms so they are the same measurements as a stock C5. Thanks in advance
      Batesville, IN
      Just an option, but you could buy the bare subframe from Art Morrsion and use all of the parts from the C5 Vette that you already have.
      http://www.artmorrison.com/inventory...puKtutTEpX.php
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
      Aug 2006
      I saw that but im also going to put the C5 IRS in the rear since I have all of that too.
      Auburn, WA
      FWIW, you can't just mock up the suspension with factory measurements, then simply narrow it to fit your vehicle. It can get complicated. So even if you got the angle of the control arms like the OEM geometry, it still may not be optimal. The camber curve would be OK, but steering geometry would be pretty messed up.
      Now I may be jumping the gun here, but you may want to get a copy of RCVD and purchase WinGEO (or Suspension Analyzer) and go that route. Planning at this stage is key.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Fontana, CA
      Yeah, don't rely on *Corvette* geometry to be right for your car. Analyze the way the parts need to be configured for optimal handling on *your* car.
      Nick R.
      Apr 2002
      Not sure your desired results with the car (not enough details provided) and I agree that a cut and paste may not be the highly optimized-over the top-I've got the best set-up out there solution but I'm willing to bet it will be better than what your car left the assembly line with.
      --JMarsa
      Aug 2006
      I just bought the RCVD book. Thanks for the insight, I knew that the steering would need to be adjusted. Are there any other Suspension Analysis Programs worth lookin at? Thanks in advance
      Auburn, WA
      Quote Originally Posted by 68RS350
      WinGEO is my favorite.
      Matt Jones
      Mechanical Engineer
      Aug 2006
      So say I were to use the C5 components. Do I dump all of there measurements into this program, my wheel base, track width and all that stuff and then determine stuff from there? I know you just dont type that in and boom you get the right set up. Does this have generic setups or what?
      Apr 2002
      I think that the Suspension Analyzer program has a C5 file built in.
      --JMarsa
      Auburn, WA
      Right, you need to be able to properly interpret the output values. You'll get tons of info like steer change, caster change, FVSA, SVSA, roll center, jacking forces, etc etc. That's where RCVD and actual seat time come into play. All those goofy numbers have absolutely no meaning if you don't know what to do with them.
      Another method that can work, but is often shooting blind, is comparing your values to a known good setup. Aim for similar amounts of toe change (and the direction of the change is key), camber gain, blah blah...and adjust it for what you vehicle *might* need. If this is the route you go, you should make everything adjustable because you'll probably need to play with it later.
      If this is just a street cruiser, copy the C5 geometry and just make sure the steering is correct.
      Matt Jones
      Mechanical Engineer
      Aug 2006
      Awesome, This will be just a street cruiser. I know you guys moved your upper control arm on your subframe. Besides figuring out the steering is that anything majorly wrong with upper placement of the arm?
      Auburn, WA
      No, there nothing really wrong it the OEM placement. OEM geometry is quite good, really. I just knew I could make it better for it's intended purpose.
      Matt Jones
      Mechanical Engineer
      Aug 2006
      Hey, man thanks for the help. I might be pm'n you with any questions I have. I might need some help w/ coilover mounting. I just need some insight im nto asking for the magic combo that you guys spent the R&D just need the general direction and understanding. Im gettin ready to graduate College as an Engineer so i understand most of it just need to be pointed in the right direction.
