Results 1 to 17 of 17
01-01-2005 #1
Hotchkis Front Coils - Ride Height Question
For those of you with Hotchkis 2" drop coils.......
Were you satisfied with the ride height (vs. stock) of these coils or did you have to cut more coils off?
I just installed the passenger side new Hotchkis 2" drop front coil in my '70 Nova today. After re-attaching the spindle I temporarily mounted my wheel. Then I placed a jack under the a-arm (near the lower ball joint) and jacked up until the frame came off the jack stand. My thought was that I'd be able to view the ride height since weight of the car was on the new spring.
Well, I was dissappointed to see that the distance between the top of the tire and the fender lip was about 2" MORE than the old stock springs. Maybe this is because the car isn't on the ground, I dunno, I just hope it sits lower than stock when all is complete.
Any opinions, comments welcome.
Dan
01-01-2005 #2
- Dec 2004
- North Jersey
- 983
Having the suspension loaded will make a big difference. When we put the Eibachs in my '88 SS, the car was still without a motor or trans. Even after putting everything else in, it still seemed to sit high. Once I drove it off the ramps and loaded the suspension, it sat just right.
Just my experience, YMMV.Steve Ragusa - North Jersey
2006 Infiniti G35x
01-01-2005 #3
