Results 1 to 20 of 38
Thread: square tubing cage
08-08-2007 #1
- Dec 2004
- kansas
- 17
square tubing cage
who makes or can make a hoop made of 2x4 to 2x6 tubing it doesnt have to be those exact measurements. for a first gen camaro.
thanks for any help
08-08-2007 #2
- Jan 2006
- Rockford, Il
- 157
why? a rectangular or square tube does not bend like a round one. it will crush on the inner radius, which is considered wall fatigue and it will just fold up if it ever needs to save your life. cutting and welding is better but still not equal to a properly bent round tube. then you have to factor in protecting yourself from the corners of the tube. there is readily available padding for round tube, designed and certified for the purpose, try and pad flat surfaces on a sq. or rect. you will be on your own there. then there is the aesthetic point, it is straight with sharp edges, in sq, or rect. it will look out of place in a car with a lack of geometric shapes. sorry , i'm not trying to shoot you down but from a safety standpoint it just isnt. many companies will sell you a basic hoop cheap, and you can have one bent custom by an infinite number of companies with a little legwork. i have seen show cars with oval bars for hoops, cant weigh in on the safety, it is usually two bars bent identical and then filled with sheet metal, or a carefully cut round tube that is then ovaled with the addition of sheet metal strips. again sorry i didnt mean to break you down or hurt your feelings, but your idea could just leave you DEAD! Dan
08-08-2007 #3
