Thread: Subframe Connectors
12-31-2004 #1
- Aug 2004
- Clovis, Ca
- 109
Subframe Connectors
I took this week off to burn up some vacation time and have made some progress. I got the rear suspension all welded up and reinstalled and started on the subframe connectors.
The SF connectors are made out of 2 X 3 X .120 rect. I wanted to be able to remove the subframe so I made some brackets that will weld to the SF and bolt to the SF connectors. I installed crush sleves inside the connectors, though I don't think it was needed with .120 wall.
I also wanted to fit the connectors as close to he SF as possible so I had to make enough room to install the body mount. When I boxed the end of the connector I had to weld in a piece of 2.5" tubing to make room for the body mount.
Dave
