      Norwalk, Ct
      Country Flag: Wales
      Tire care/storage
      What is th ebest way to store tires??
      I am using 345/35-18's on the back fo my car and as they are no longer made, I recently picked up another pair, want to keep them nice.
      Whats the best method of storing them??
      Nick
      Nick Townsend
      Pro-Vintage 69 Corvette
      64 Riviera Custom - 20's, air bags
      Shell Valley Cobra
      2005 Penske Racing Dodge Charger Nextel Cup Car "Rusty's Last Round"
      Nov 2001
      Sacramento Ca
      wrap in a thick plastic bag, tie shut, put in a cool dark place. store on the sides, don't stack them.
      If storing them inflated on a rim, deflate them by 25% than recommended pressure.
      From the internet
      DO STORE
      * Where area is clean, cool, dry, dark and well ventilated but with a minimum of circulating air so that tires on the bottom of a stack retain their shape. (if stacked. I don't recommend it. TonyL)
      * Whitewall to whitewall to avoid staining.
      * Protected by an opaque waterproof covering, if outdoors, but avoid creating a heat box or steam bath.
      * Where tires are raised off the storage surface, if outdoors.
      AVOID STORING
      * Where area is wet, oily, greasy.
      * Where subject to extreme temperatures.
      * In the same area as an electric motor or other ozone generating sources (if there is a question, check ozone levels to be sure they do not exceed 0.08 ppm). (Hence the whole "bagging them" thing. compressor motors generate ozone, and who doesn't have one in their shop? -TonyL)
      * On black asphalt or other heat absorbent surfaces.bagging
      * Adjacent to highly reflective surfaces (i.e., snow covered ground or sand).
      * On piers, ship decks or other open, unprotected areas.
      Tony Langlois
      1966 Corvair Monza
