Results 1 to 16 of 16
07-22-2007 #1
Second Gen Power to manual issues
OK converting the 79 Camaro that will get the 500" Pontiac motor to manual brakes. The power booster rod is on only one side of the pedal and there is also alot of play in it so that helps offset it.
Now swapping to manual and using a clevis look where the pedal actually centers in the hole. Is there offset clevis? Instead of centering the clevis just put a nut in the middle and bolt it up?
FYI the MP adapter plate is not needed and doesn't fit the booster stud spacing. The MP rod is WAY too long and I don't think it can even be shortened enough to use.
