      vallejo,ca
      1970 camaro rear disc
      have any of you converted your rear drums to disc and did you use a kit or have converted from a 4th gen i hear this is possible just looking for some insight on this thanks to all that reply
      Feb 2007
      yes this would be good info./ was told that the rear 4th gen rear brakes
      due to the parking brake was the best setup to do with front c-5 brakes
      would also like to know any info for the sec gen camaro and part numbers for stag shocks
      98+ 2wd rear Blazer disks are similar to the f-body but only have a hair smaller rotor.
      Heres some info. Ideal with the staggered shocks you need one axle mounting plate from a 4wd blazer and one from a 2wd to easily use the parking brake setup.
      http://www.nastyz28.com/forum/showthread.php?t=49459
