07-09-2007 #1
New to Pro-Touring
- Jun 2006
- Kewaskum WI
- 13
Alcohol compatible Fuel Injectors for 350 TPI
Has anyone found any injectors that could work with E85 and fit in a 1989 TPI 350 small block chevrolet.
07-10-2007 #2
Any injectors should be compatible. Almost all gas has alcohol in it anymore.
Your ECU may have to be reprogrammed to work with E85 (depending on your type of O2 sensor) and your engine would have to be modified to get it to take advantage of E85 properly.1970 Corvette Convertible
Fuel Injected, Supercharged 406 SB Chevy
07-11-2007 #3
New to Pro-Touring
- Jun 2006
- Kewaskum WI
- 13
Z-Man What kind of EFI are you using and what is the brand name of the injectors you use.
07-12-2007 #4
I'm running a Holley C950 system. My injectors are 65lb Bosch - they came with the FI unit.
