Results 1 to 20 of 22
Thread: Tig or mig ?
07-06-2007 #1
Tig or mig ?
I will modifying the fuel tank for EFI. Is it best to use TIG or MIG? Last time i did it i had trouble with leakings. And had to grind and weld again so it warped. I used mig. Now I have bought me ESAB 250 amp Twintig TIG and have my old 140 Amp Kemmpi MIG. What to use. Thanks for any input...
Olav
07-07-2007 #2
- Jun 2005
- 543
It doesn't matter if you are using the correct alloys and you are skilled with either machine.
Originally Posted by Olav
There is nothing magical about a TIG welder, it just gives you more control because YOU decide how much filler to add, and YOU decide on the fly, how much heat.
You can get the same results with a MIG welder, if you know what you're doing.
So do whatever you feel the most comfortable with.
Oh, and peep in on this thread: https://www.pro-touring.com/forum/sh...hlight=Mathius
We fought out the whole TIG vs. MIG thing a long time ago.
Mathius
07-07-2007 #3
Oki! think I will try my new TIG. Must practise on some other parts first. Have only used it on Alu. earlier. How thick wolfram do you recomend for 0.8mm steel. and how many amps.
I'm working as mechanical supervisor now on a ship yard and have been working "on the floor" for 20 years. Mostly machine repairs and machining, so my welding skills are little over average mechanic. but when it comes to TIG and thin metal it's not so good.
Thanks for any input....
Olav
Thanks Olav
07-07-2007 #4
- Jun 2005
- 543
Ok, first I have to ask... is 0.8mm the correct measurement?
Because by my calculations, that's like 0.0026 inches, which is thinner than 30 gauge, which is not going to be anywhere near thick enough for a fuel cell for EFI. (given that 1mm = 1/32 inches)
You need like 14 gauge aluminum minimum for a fuel cell.
Mathius
07-08-2007 #5
I will not build a new fuel cell. My plan is to modify sump/ baffle the original tank of steel....
Olav
07-08-2007 #6
- Jun 2005
- 543
I'm sorry, I thought I read that it was aluminum... still, a steel fuel cell 0.0026 inches thick? That's crazy. It's no wonder you had leaking issues.
Most guys here use 16-18 gauge for steel fuel cells (usually stainless) and 14 or better for aluminum.
I really can't recommend much for you. I don't think I've ever welded anything that thin. I mean that sounds like tinfoil. Are you sure you measured right? Are you sure it isn't 8mm?
Mathius
07-08-2007 #7
Wil measure again. But i think it's not any thicker than normal sheet metal. Have cut out a part of the stock tank and it's thin.....If I make the sump/ baffle of thicker plates than the tank is made of must i use more/ higher current and it's easier to warp the plates.
07-08-2007 #8
- Jun 2005
- 543
Try to use calipers when you measure it, if you haven't already. Actually 8mm is pretty thick stuff, I clearly wasn't thinking when I wrote that.
Mathius
07-08-2007 #98mm are the same as 5/16"
07-08-2007 #10
- Jun 2005
- 543
Yeah, which is bigger than 1/4" inch. It'd be heaviest fuel cell I ever heard of.
Mathius
07-08-2007 #11Hi!
Measured the steel in the Camaro tank about 0.90mm or so....(1/4" are 6,35mm)
07-08-2007 #12
- Jun 2005
- 543
Ok, that makes a lot more sense. That's about 19 gauge sheet. Still kind've thin, but not surprising.
It's been a long time since I've TIG'ed, but I'd say somewhere in the 50 amp range, with a 1/16" rod. Gas at somewhere around 11 cfh or 20 psi.
But there are guys on here that do this every day. Now that we've established what size material, someone else should be able to give you better settings.
Mathius
07-08-2007 #13
- Aug 2006
- Vinland Kansas,66006
- 647
