    Results 1 to 15 of 15
      La Plata, MD
      Looking for paint gun!
      As the title says looking for a paint gun. Since I am new to painting I will be just starting with primer and sealers. Hopefully after some experience I will be able to at least be able to spray color on firewalls doorjambs and the like. I recently purchased a new compressor and am now looking for a paint gun and some other accesories. The things I need to know are Siphon or gravity feed, tips sizes, vendors, and prices. I don't want to break the bank but I don't want to short myself either. Also any filtering tips for keeping water and oil out of my paint would be appreciated also. Once I get the equipment identified and bought I will check back on painting techniques. Thanks,
      Bruce
      Ortonville, Michigan
      Head on over to this place....http://www.paintucation.com/
      Great for the novice.Try the message board.
      Chris
      1971 RS Z28 Pro-touring thing......will it ever be done??
      La Plata, MD
      Thanks Chris I will check them out.
      C'mon nobody has a paint gun they would recommend!
      Bruce
      Nov 2004
      Forney, TX
      I have two Anest Iwata LPH-400's. One for Base, One for CLear. I've used almost every gun on the market and used Sata guns exclusively--until I tried the Iwata. I liked the Iwata so much that my $400 Sata-Jet 2000 became a primer gun! The Iwata and the Sata are pricey, though. If you want a good, inexpensive gun- I have to recommend the DeVilbiss Finishline. You should be able to find it online for around $100. It's an all metal gun, a little heavy-but it sprays very well. I still use mine from time to time. Sharpe has recently come out with a new line of well-performing, inexpensive guns- but I haven't tried them. Good luck.......
      __________________________
      Boyd
      1972 P/T Style Chevy Short-bed - coming soon
      Specialty Auto Services
      La Plata, MD
      Boyd,
      Thanks, thats exactly the type of feedback I am looking for. I will look them up, again thanks.
      Bruce
      Boring Oregon, go figure:)
      I good learner/primer gun is the HVLP gun sold by Harbor Freight. I have one that I use just for primer. I also have a Binks M1G for base and clear coats and a Sata Detail gun. I agree that the Sata is great but expensive. I used the Harbor Freight gun for years painting enamal and single stage urethane's but got the Binks for base/clear systems. The main thing is practice as much as you can.
      Dan
      La Plata, MD
      I found this and it looks pretty good to me, what do you think? Its the devilbliss which is a special on the main page with case and several tips and is $229.99
      [url]http://www.spraygundepot.com
      Mar 2003
      Lafayette, In.
      I have always used Sharpe "Cobalt" hvlp guns, i just bought another for shooting clear.
      you can usually get them on ebay for $75-$125
      i have painted or primed all my vehicles using a Sharpe "Cobalt" gun ! :icon996:
      this one is currently in process of being finished up!
      In process!
      1972 C10
      Roadster Shop Fast Track chassis
      LS376/525
      Nov 2004
      Forney, TX
      Quote Originally Posted by Blaster11
      blaster, if you don't mind changing tips when you go from primer, to base, to clear - it's probably an okay deal. The tips are about $25 separately and with all of the tips included the price is about right.
      trilogy, the Z looks sweet...very smooth finish... :icon996:
      Boyd
      Austin, in the great Nation of Texas
      Devilbiss Finishline
      I bought that same gun you're looking at from spraygundepot and it works great. no complaints at all. Spraygundepot has been a good shop to do business with as well.
      Oswego il
      the harbor freight gun is very good to learn with, ive used it for primer and even used it to blend in a 1/4 panel in red (not the easiest thing) on a 91 camaro that was a dialy dirver. just ruined it shooting epoxy though. i liked so much i bought another. have two sharp cobalt guns for base and clear that im very happy with. i think you should have seperate guns for primer and paint. anyone have specific tip size recommendations for paint and clear???
      NY
      I have never heard anyone actually like those Cobalt guns. They were notorious for spray issues when they came out. I actually bought a primer version and when I ran into problems I called Sharpe and they were so aware of problems that they just sent me another gun no questions asked. Astro is a cheap Sata knock off that works great on low air supply. They clean up fairly easy. Do not go crazy with 1st gun. Watch air consumption numbers and most of the better guns use up more than you will be able to deliver with home compressor. Plus with the $99 gun when it is giving you problems you simply toss it and get another. That Astro with a 1.8 will handle most surfacers with no problems. It actually outperforms MY Sata KL primer gun. Why?? who knows and I am to busy to figure it out. Unless you are into production work stick with the import stuff. Brian
      Michigan
      I bought a sharpe finex primer/surfacer gun for around $75 and was very impressed with it. Works great for primers with the 1.7 fluid tip. Very easy to clean and I like the aluminum screw on cap compared to my devilbiss gti clearcoat gun with disposable lids. Since I only paid 75 for it I was going to buy a new primer gun for each car I do but it still looks brand new after countless hours loading primer on the 53' eldorado that I'm finishing up. Great buy for the money. It has two features that I must have in a primer gun.
      1. ability to spray thick materials
      2. Ease of cleaning
      Boston, MA
      I use a new DeVilbiss and love it! (I have 1.3, 1.4, and 1.5 tips)
      My last gun was a Finishline and I ended up tossing it after two jobs. It was an older model that had replacement plastic tips. A total waste and mess.
      I've spent more time during painting trying to fix or set-up a crappy gun than painting. My suggestion is to not skimp on a good gun. The better the gun, the less work you have to do after you shoot. Just my 2 cents.
      ~Ryan
      Boston, MA
      Pictures and line
      Here is the link to the gun I've been using.
      Paint Gun
      It's the GFG Gravity Feed PLUS Spray Gun.
      Pictures of the last paint job with it:
      ~Ryan
