Thread: 700r4 ???
07-05-2007 #1
700r4 ???
dose any one know if a 700r4 will fit with the stock drive shaft or dose it need to be cut down for a 65 chevelle?
thanks chris
https://www.pro-touring.com/forum/sh...ad.php?t=22724
65ss chevelle
95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
63ss nova
350:cam headers,roller rockers.pete jackson gear drive,
th350 shift kit 3,500 stall
3:73
**Drive it like you stole it!!
07-08-2007 #2
- Jul 2005
- Marshall , MO
- 699
It will have to be shortened to fit the 700 do a search at TC you will find more info.
Brad Shepard
69 Malibu
Marshall, MO
07-10-2007 #3The 700 is about 3'' longer then the 350. and it also has a farther back mount so you'll need to make an adapter plate to locate it to the crossmember.
But if you have a 9'' tailshaft on the 350 then there is no difference in length from the 700
1993 Camaro Z28
2001 Camaro Z28
1969 Camaro
