      Eastern Virginia
      Need suggestions for running LT1 ign wires.
      I "was" going to use some brackets I made that uses the 2 center bolts of the valve covers & run the wires above the headers. Worked fine on the driver's side. I don't think it would work so well on the pass side. I am using the F body accessory bracket. Would like some suggestions and/or pics of others. Anyone know of brackets that hold the wires along the side of the block under the headers similar to the factory setup? I would use factory setup but I have Taylor 8mm wires & they will not fit.
      Scot
      86 Monte SS
      woodstock GA
      i have some on my motor(pics in projects section under 67 camaro)I got them from thunder racing.com and im running the 8mm talors as well
      67 Camaro
      Eastern Virginia
      OK I am an idiot. Where is the projects section? Are they "Made for you" looms?
      Scot
      86 Monte SS
      the pass side is always pain with the oe bracket and headers
      the best way is to run the wires under the headers like the oem and you could use the cheap champ style holder and mout them to the oe metal tabs that bolt to the block, you wil that to remove the plastic holder form the tab and drill a hole through them.
      Oct 2003
      South Lyon, MI
      I'm running the thunder racing set-up. Great set up. I'm running them along the side of the valve covers.
      Kevin
      Eastern Virginia
      AHHH I hate running these Fcuking ignition wires!!!
      Scot
      86 Monte SS
