    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 46
      Jan 2003
      Arizona
      Billet Cowl Induction Trim Plates
      I posted this in the open section, but I see Larry has started a new products topic so here goes:
      ProStyle Billet Cowl Induction Trim Plate from Twist Machine.
      If you run a cowl induction hood without the factory flapper door, Twist offers a great way to finish off the opening. The trim plate fits factory and OE style hoods using the original mounting holes. Installation does not require hood removal. Price is $55 which includes stainless steel button head hardware.
      To order, or for more information, contact Twist Machine, LLC at:
      631-610-4186
      www.twistmachine.com
      ________________
      Steve Chryssos
      Eastern Virginia
      Any idea if these will fit the Goodmark after market Monte Carlo cowl hoods?
      Scot
      86 Monte SS
      St George Utah
      looks gOOd just add some mesh and your done.
      boerne texas
      got mine.
      rickk
      Dublin, CA
      I second the Goodmark application question!
      How about Harwood? Just wondering ...
      jp
      John Parsons
      Jan 2003
      Arizona
      I'll post up some measurements for the non-OE guys--including the bolt pattern. We won't be doing mesh, since it doesn't offer any protection rain or snow or sand. Unless you're worried about varmints or critters or something, that mesh is just in the way.
      ________________
      Steve Chryssos
      Dublin, CA
      It is the birds I worry about! I assume this piece just bolts on the the existing cowl, so on a Goodmark 9if measurements are the same, the existing mesh could be left in. I guess what I am saying is that this piece looks to be more bling then function
      Brent
      Jan 2003
      Arizona
      Correct. It is a trim plate. But it is our contention that large openings permit better airflow than mesh. The original design is a flapper door-no mesh. And I 've seen numerous occasions where the wrong air cleaner assembly and mesh hood scoops has had a negative impact on carburetor tuning--especially at idle and part throttle. Swap an air cleaner, pop the hood or remove a mesh laden "dead dolphin" scoop and mysterious idle problems subside. Imagine moving all of the mesh's horizontal and vertical (or diagonal) wire elements together and they add up to a substantial percentage of the opening. Here is a great source for mesh. http://www.mcmaster.com Search "wire mesh screens" Percentage openings are listed. It's a prety cool webpage. You will see that the minimum blockage is 20-25%. So, in many respects the mesh is the bling that counters function.
      You are certainly welcome to sandwich mesh between our trim plate and the hood flange, but after careful consideration, we made a decision to omit mesh and leave the decision up to the end user. I'm not trying to be snippy--I just want to be clear that we did or homework.
      ________________
      Steve Chryssos
      Dublin, CA
      No offense taken. The Goodmark hood I have has a heavy gauge mesh welded on the inside of the opening, could be removed, but would be a bit of a pain. My complaint about the design is that the window washer nozzles have to be mounted inside of this mesh and are a wench to get at.
      I guess if you are talking about a stock cowl application the mesh restriction arguement makes sense. But I would be surprised if an aftermarket cowl hood did not flow more air then a stock non-cowl hood. For what it is worth, I think you have taken the right route as it is easy to add mesh if you want it, leave it up to the customer. All in all, very nice product.
      Brent
      Mar 2002
      Redwood City, CA
      I just want to see what it looks like from inside the car when the hood is closed.
      Allen Ortega
      Jan 2003
      Arizona
      Quote Originally Posted by barno68
      ....I guess if you are talking about a stock cowl application the mesh restriction arguement makes sense. But I would be surprised if an aftermarket cowl hood did not flow more air then a stock non-cowl hood. For what it is worth, I think you have taken the right route as it is easy to add mesh if you want it, leave it up to the customer. All in all, very nice product.
      Brent
      Thanks. Yeah the factory design is built around that old flapper door. The shape is small and irregular. Some of the aftermarket stuff is probably better. Flangeless (wide open) hoods are best at getting air in at speed and letting heat out at idle. Mesh was a given at first. We barely gave it a second thought until we reviewed that McMaster Carr page. The stuff that only blocks 20-something percent looks like chicken wire, so that was out of the question. We are always surprised by the twists (sorry for the pun) and turns that the product development process takes--even for simple parts such as this. It's one thing to make a custom part, but making a bunch of the same part that goes in a box and gets shipped out to a wide cross section of people is a whole other ball of wax.
      I'll post a print as soon as possible for you guys that want to try and retrofit the design to aftermarket hoods. Rick Kirkendall has offered to test fit the plate on a 2nd gen Goodmark hood.
      ________________
      Steve Chryssos
      Jan 2003
      Arizona
      Quote Originally Posted by zbugger
      It's a tough picture 'cause of the windshield. I will try again on the white convertible when it gets back next week.
      ________________
      Steve Chryssos
      Northwestern NJ
      Quote Originally Posted by Samckitt
      Nope. At least not without mods & fabrication. The Goodmark hood has a flat screened inlet, no provisions for the stock Chevelle style flapper.
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Jan 2003
      Arizona
      We ended up making the backside completely flat to facilitate adaptation. A customer has agreed to try one out on a 2nd gen goodmark hood. At the very least, I expect to see some drilling involved. Shouldn't be rocket science if the ourter dimensions are right. It's a moving target, though. So we will proceed cautiously on the non-first gen stuff.
      ________________
      Steve Chryssos
      Huntington Beach, CA
      Hmm shots of it on the car from the inside would be cool. I have a cowl hood of unkown origin that appears to have bolt holes in same spots and would be nice to put a finishing touch on it.
      Jan 2003
      Arizona
      Will do. Just mounted one to the white convertible which makes it easier to shoot through the windshied without getting glare. I'll take a piture of that. Looks hot!!
      ________________
      Steve Chryssos
      Mar 2002
      North California
      Thats simply a gorgeous piece of billet right there!
      -Jim
      Santa Barbara, Ca
      This is something that I need. Steve, glad to see you are coming up with new products for our cars.
      Andy
      Jan 2003
      Arizona
      Thanks guys. That's just the sort of encouragement that I need considering that I'm at the shop on a Sunday at 6PM brushing metal. Shipping starts tomorrow!!!! Time to go home.
      ________________
      Steve Chryssos
