06-12-2007 #1
Going with A/C finally Need some help
Well im sure someone has done a 69 camaro, so which system works the best? And since i dont have an A/C switch panel (removed) how would i control it? Thanks
1993 Camaro Z28
2001 Camaro Z28
1969 Camaro
06-13-2007 #2I have installed a vintage air gen.4 magnum in my 70 chevelle and it work's great. check with Frank at Prodigy customs he can hook you up with a system for your camaro. I am in Fort Myers if you want to check it out.
06-13-2007 #3
Banned
- Aug 2003
- Orlando, FL
- 8,745
Yup, you are a little more lucky then my friend Wayne as there is a bolt in kit for your car. Wayne had to work a bit more and we had to put together a custom kit for his Chevelle.
Call me if you like at four zero seven 832 1752. i have a unit in stock. We are in Orlando ourselves
06-13-2007 #4Im in Cape Coral so i just might have to stop by and check your system out. How much for the GEN IV system for my 69 Frank?
1993 Camaro Z28
2001 Camaro Z28
1969 Camaro
