      Metamora, Illinois
      Disc Brake conversion - which one??
      I am getting ready to purchase my four wheel disc brakes, for my 69 Camaro, before the end of the year. I wanna run 13" rotors up front and 12" out back. I have narrowed it down to touring-classics and Baer kits. The Baer kit is about $230 more. The car will be used as a weekend/daily driver and I would like to do the Hot Rod Power Tour in the future. Any recommendations??
      Thanks in advance,
      Rod
      Delaware, OH
      I've purchased, but not yet installed, the Touring-Classics front/rear kit. I'm impressed with the parts/quality/instructions and most importantly their good customer service. A lot of folks use Baer, but I don't have any personal experience with that brand.
      Dan
      Scottsdale, AZ
      Quote Originally Posted by rocketrod
      Thanks in advance,
      Rod
      What do the Bear's cost?
      Metamora, Illinois
      The front and rear Baer kits runs $1560 and the Touring Classics kits are $1330, listed costs are without S&H
      Rod
      Delaware, OH
      FYI... Until 12/31/04 Touring Classics has all front systems 15% off & all rear systems 10% off according to their web site.
      Dan
      OK
      re:
      all baer is, is a name. They are just C5 dual piston calipers with the baer name. I would check out touring classics and even speedtech sells a kit as well. Wilwood has a great system, but they are a little higher.
      Scottsdale, AZ
      What bear system are most people useing? G/T or the race 4 or 6 piston with no parking brake for the rear? As far as looks go the 4 piston calipers look cool, kinda like the old 4 piston set up on the 67-69 Z28's. If you actually plan on useing the car on the track which should you buy?
      Hey Guys,
      I just purchased the four piston wilwood system w/ the 12.2 disks on each corner. This also comes w/ the drilled, zinc coated setup that has four pistons per caliper. In the midst of getting it on, but so far looks like a good system. I'll drop a line later and see if it stops hard enough to mush my face against the windsheild, which it should for the price!
