      NJ
      C5 brakes and TQT II's
      Has anyone run 6 piston C5 wilwoods with 17" TQT II's how much wheel spacer have you had to run for clearance. any help would be great.
      thanks,
      -Tom
      Houston, Tx
      What rim size? I assume that 18's would be okay. 17's would definitely need something to make them fit.
      NJ
      They are 17's I trying to find out what the minimum clearance should be for possible expansion issues and deflection. I need to run the least amount possible and was hoping someone has done this before I make another mistake when I get this set of wheels.
      Houston, Tx
      Quote Originally Posted by TBART70
      I am almost positive that c5 brakes won't clear 17's unless you do a hybrid setup (using c4 rotors) like those sold by Touring classics who is a sponsor at this site
      Call Noel and let him know what you are after. He will be able to tell you for sure.
      NJ
      I already have the 6 piston 13.09 in wilwoods.
