      absecon, new jersey
      76 trans am rear rim size
      Im most likely inheriting a 76 trans am in the next week.I have 17x9.5 with 4 1/8 bs boyd coddington starburst rims on my 73 vette,can i put them on the trans am on the rear ,my fronts will fit 17x8 4 inch bs.Im looking to get new rims for the vette anyway.
      73 corvette chop top silver LS6 motor ,LS6 intake,700r4,2400 pro torque convertor ,3.70 gears,modified hooker sidepipes to fit LS1,17 x9.5 boyd starburst,nitto 275/50/17-255/50/17 tires,vb&p suspension,nitrous,L-88 headlights,autometer guages.L88 hood,flares,spreader bar,vb&p sway bars
      May 2006
      Northern NJ
      You should be able to fit them. Most guys with 2nd Gen Firebirds/TA's will run a 17x9.5 with a 5.5 backspacing. They generally run 17x8 with either a 4 or 4.5 backspacing on the fronts.
      Where is Absecon NJ? I'm in Jersey and have never heard of that town before...
      1974 Pontiac Firebird Formula
      1971 Pontiac Firebird Formula Clone
      1973 Chevrolet Camaro
      absecon, new jersey
      yeah i figured theyll probably not have enough bs,maybe stick out an inch or less ,im 5 minutes out of atlantic city.
      Jan 2007
      The fronts should be fine with 4"... but yeah, the rears will probably stick out a bit past the wheel well lip... I've seen 9.5" wide rims run 5" backspace though and it looked good... so it may not be too bad with 4.5".
      Post some pics when you get the car.
      1994 Corvette
      absecon, new jersey
      thanks i guess ill try it and see if not ill look for rims.
