Results 1 to 15 of 15
Thread: 351 c twin turbo
05-25-2007 #1
351 c twin turbo
well i plan on building one but dont know where to start.... the motor assembley part i got (n/a i mean) but after that im lost
where can i get a good set of turbos ive saw that one guy with tha 71 chevell bought his used from a race car....
where do you get blow through carbs..... and lastly how much will it all cost im guessing 6k total is that too low??????
i can get a 12:1 comp. compleate motor for 400 but obviously i cant run a turbo with that compression ratio so 8:?? is right correct????
help me out guys i want to build one so bad thanks for tha help
05-25-2007 #2oh and my goal is around 14lbs of boost max i want 600-700 or so hp is that going to be fesible......
i know the plumbing is tha hardest part.... i might be able to find sumone to do it....
05-25-2007 #3Were you planning on using a factory block? 2 bolt mains and 700hp would scare the crap outta me, also having a carbureted turbo setup.... You should STRONGLY consider efi.
Brian
'68 Camaro
05-26-2007 #4the block that i was going to get might possibly have 4 bolt mains havent got anymore info on it but i definetly know that i need to strengthen that bottom end.... I like efi but i dont like the price..... what are the cheapest they get too and what efi system would you recomend
05-26-2007 #5
