Results 1 to 11 of 11
Thread: Help, I screwed up color sanding
05-25-2007 #1
New to Pro-Touring
- Feb 2005
- Grand Rapids, Mi.
- 42
I just sprayed a 69 camaro silver. The base layed down real nice. But the clear has some orange peel in it. I was wet sanding the roof starting with 1200 grit. On one of the corners I went through to the sealer. It is a little smaller than a dime in size. Is there any way to spot this in and make it look good? Will I have to reshoot the roof? If so, I will probably have to do most of the shell since there are no break lines between the roof and quarters. What is the best way to fix this? Thanks
1968 camaro rs convertible, 02 LS1/4L60E
05-26-2007 #2
New to Pro-Touring
- Jun 2005
- Crescent City,Ca.
- 24
is it still cut with 1200 or did you go ahead and buff?If its still cut just use a touchup gun,blow a little color on,the clear,recut and buff.Just take your time silver is a bitch to match.
05-26-2007 #3
New to Pro-Touring
- Feb 2005
- Grand Rapids, Mi.
- 42
Thanks Scott, I did already buff the roof. Do I have to hit the roof with 1200 again first?
05-26-2007 #4
- Aug 2004
- England
- 1,042
You might have to go with 800 as the paint might not grip on 1200.
05-26-2007 #5
