Results 1 to 20 of 24
Thread: Martz rear suspension
12-20-2004 #1
I've done a few searches here and it seems most serious corner carvers would not go with this kit due to suspension bind.
My question is if I fabbed up a new set of upper and lower bars to run 3/4" heims, would that help some of the binding issue?
I'm considering this kit as I am mainly going to be drag racing the car but would like to be able to switch out all 4 coil overs, re-connect the front sway bar and play in a few corners.
I'd prefer coilovers rather than leafs for the adjustability and don't want to cut in to the floor.. Thanks in advance.
12-21-2004 #2So 78 views and no responses?
12-21-2004 #3No. The bind comes from a combination of a redundant restraint (4th longitudinal link) and link angles, not from the pivot points. Big soft rubber bushings would help, but they'll introduce non-linear roll resistance.
Originally Posted by 73-TYPE-LT-LS1
A true purpose of coil overs is adjusting corner weight, not to change the ride height. That can be done on leafs, even though it's a little more time consuming. Leafs are much better than poorly executed link suspension, which you probably would end up with if you don't alter the floor. There are drag cars that run 8s with skinny slicks with leafs, and there are kick ass road race cars that run leafs.I'd prefer coilovers rather than leafs for the adjustability and don't want to cut in to the floor.. Thanks in advance.
Note: I don't know what Martz kit for F-body looks like, but generally speaking stock floor panels of factory leaf-sprung cars compromise geometry of link suspension.The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
Signed,
A driver who laps Big Willow at 1:42.6 in a 134hp BMW - and I am still considered mediocre.
12-21-2004 #4What if:
Here is the Martz rear suspension. http://www.martzchassis.net/camaro7073rearinstall
Here is something I found interesting (Look at the 3 pics of the 3 link, mainly pic 2) http://www.msnusers.com/69LS1camero
No imagine re-inforcing the DS loop on the Martz and running a 3rd link from that point.
Bad idea?? There would be very little cutting of the stock floor pan if any.
Couls swap to the 4-bar when drag racing and switch to the 3-link for road racing.
12-21-2004 #5
- Aug 2004
- 957
Gulp! Where to start?
A three link, versus a four link, will not have any disadvantages on the strip if it is designed correctly. No need to switch back and forth, at all.
The Martz unit is clearly (I hope) designed with packaging in mind, rather than performance. The most startling thing I see with it is the incerdibly short SVSA, if you are not going further than the drag strip, or the corner grocery store at 50 MPH, it "might" be acceptable, if you have a lot of room to stop. Okay, that may be an exaggeration...
Before you select a rear suspension approach, decide what it is you want from the car. If you want it to look really cool, then there are some neat IRS units that could be adapted. If you want it to fit in the stock car configuration, it is hard to beat a really well set up leaf arrangement. If you want to drag race, but don't care about cornering, then many of the highly available drag race four link/ladder bar setups will most likely work just fine.
If you want to road race, well, then there are few available options, but this venue is perhaps the most challenging of all suspension applications, and you'd better get it right if you know what is good for you. And, by the way, if this IS your intent, you are in for a long, fun, incredible education. Eh, Katz/Chicane/Pozzi, et. al?
Mark
12-21-2004 #6
