    Results 1 to 15 of 15
      Jan 2007
      4130 TIG welded Custom Roll-bar
      Here is a custom TIG welded 4130 roll bar we did for the owner of Stangwerks.
      everything is 4130 and TIG welded, even the plating into the chassis.
      Jason
      Bringing innovation into the industry one build at a time!
      Jan 2007
      mas photos!
      Jason
      Jan 2007
      i forgot to add this in, There is a removeable section in the harness bar. We use a specialty machined unit that is TIG welded in and provides an interlocking section that will never rattle and be very strong in the event of an accident.
      Jason
      Aug 2003
      Southern Louisiana
      What filler rod did you use? Did you stress relieve the welds?
      Nice work by the way.
      Kevin
      Jan 2007
      some pre heat, mild rod ER 70S. I only use 4130 rod if the entire chassis or suspension parts are getting heat treated. Say, for like 4130 or 4340 arms i would use chromo rod and heat treat the parts. I have welded several 4130 cages like this. The strength of the mild rod with the 4130 is more than enough for the forces the structure will see in this application.
      Jason
      what would something like this run by chance?
      Feb 2006
      there are many factors we consider when we price out a roll cage. If the car is brought to us completely gutted then we dont have to charge hourly for taking out interior, and that gets expensive. Because this cage is chromoly and tig welded, metal cost almost doubles over DOM, and labor time nearly doubles as well. I will send you a PM to explain costs.
      G-Machine
      562-595-5410
      www.gmachinestore.com
      www.gmachineracing.com (shop)
      Hamilton, NJ
      gmachinei forgot to add this in, There is a removeable section in the harness bar. We use a specialty machined unit that is TIG welded in and provides an interlocking section that will never rattle and be very strong in the event of an accident.
      Do you sell these machined parts that you use to be able to remove the bar. Where can I buy the they look very trick and would like to use on the cage I am building. Thanks
      Good stuff guys. Nice work, lovely welds. I used a lot of 4130 in II Much, ignoring naysayers telling me that the welds (or HAZ) would crack.
      So far, so good.
      jp
      ​John Parsons
      Aug 2003
      Southern Louisiana
      i have seen way to much 1020 tear to not use 4130.
      You do realize that plate is welded to a sea of 1020 right? And, your telling me that for everything that your shop fabricates, 1020 steel just isn't strong enough?
      Kevin
      Jan 2007
      Quote Originally Posted by gt1guy
      Kevin
      I consider 1020 a compromise when it comes to plate. Even when we build DOM cagework we use 4130 plate. Its just how i run the shop. Others will disagree with my thinking but i would rather use the best and not compromise. Sure its cheaper to use 1020 but cheap is not what we build. We build quality.
      so here is my thinking. On this pic you notice the 4130 plate welded to the "sea of 1020". This plate is 6" by 6" and the tube is 1.75". Now when the force comes down on the main hoop it will press in that circular pattern of the 1.75" tube. Now the 4130 plate will have a less chance of tearing under the force of the tube. I have seen tube tear right through 1020 like it was fiberglass. The plate is welded to a "sea of 1020", you are correct about this. This "sea" is under a larger surface area then a 1.75" tube, in fact you might even say its about 36 square inches. This spreading of the force will distribute the load into the "sea" so that tearing between the plate and the "sea" is minimized.
      1020 is a four letter word in our shop! LOL.
      jason
      Jan 2007
      and we now have the tube clamps on sale in various sizes. I will have pics up on our site soon but here is the link.
      http://www.gmachineracing.com/burgclamps.html
      tableWorkaround2(21)tableWorkaround2(2)tableWorkar ound2(2)tableWorkaround2(5)2" by .120 wall
      40
      2" by .095 wall
      40
      1.75" by .120 wall
      37
      1.75" by .095 wall
      37
      1.625" by .120 wall
      36.50
      1.625" by .095 wall
      36.50
      1.625" by .065 wall
      36.50
      1.5" by .120 wall
      36
      1.5" by .095 wall
      36
      1.5" by .065 wall
      36
      1.25" by .120 wall
      28
      1.25" by .095 wall
      28
      1.25" by .065 wall
      28
      1" by .120 wall
      26.50
      1" by .095 wall
      26.50
      1" by .065 wall
      26.50
      .75" by .095 wall
      25
      .75" by .065 wall
      25
