Results 1 to 10 of 10
Thread: XFI, fuel pump, fan connection
- Aug 2004
- Phoenix AZ
- 286
Just trying to get this thing wired up and am confused! I have an aeromotive pump controller and a DC fan/water pump controller. I see that my ECU has wires for the fuel pump and the fan, how does this come into play? Do I use the ECU wires to the switch terminal of the controllers, do they just tell the fans/water pump and fuel pump it's ok to run? Another concern is the tach signal, I understand I need one for the ECU and one for the fuel pump controller, can I splice one wire into two from the MSD box tach signal or will that screw up the signal? Thanks for any help you can provide.
04-27-2007 #2
New to Pro-Touring
- Sep 2006
- medford OR
- 4
I haven't seen an aeromotive pump controller. is it a fuel pump relay for the aeromotive fuel Pump? if so you would send a 12v to the relay and the ecu will trigger a ground to activate the relay. At least it works this way on most systems.
same basic deal with the fans. the ecu typically monitors the water temp and grounds the relay to activate the fans.
tach signal? the ecu usually shouldn't need a tach signal it sends your tach a signal. the ecu if it controls the ignition gets its info from the distributor or the crank trigger. depends on what type of motor you have. No idea why the fuel pump controller needs a tach signal unless it increases pressure as rpm increases.
I am just guessing on most of this. maybe you could be more specific on what type of units you have.
DB
04-27-2007 #3
