Results 1 to 16 of 16
- Dec 2006
- 25
Sorry it has taken so long to reply -- the pump you will need should flow at least 140 gph @ 80 psi. This will be enough to support 1200 hp. You will need some form of pump speed controller to reduce pump speed while you drive the vehicle on the street or in traffic.
-OR-
Use two pumps -- a small inline that will support the motor while street cruising and then when you get to the track or if the boost reaches a certain point turn on the second (larger pump).
Check with Kurt Urban @ W2W -- he's done plenty of these.
