      Trim Tag Removal
      i have a '61 Pontiac at the body shop. i would like to have the trim tag removed from the cowl during the work (near driver's side hood hinge), so i can clean it up and re-fasten it, maybe even have a reproduction made.
      the body shop is not familiar with the rules regarding this. as far i know, this tag can be removed for restoration, but not the tag inside the driver's door.
      does anyone know the rules in particular, and where i can reference them? is it state by state? car is in TX, and i'll prob trailer it back to MN before re-fastening the tag.
      thanks,
      Scott.
      CHICAGO SUBURBS
      It is not illegal to remove a cowl tag. The resto guys will be able to tell it was removed though. If it a stock resto you are doing, document what you are doing, maybe pictures would be enough. They sell reproduction rivets to hold the tags on.
      Kansas City, MO
      The trim tag has no legal bearing whatsoever. You can get the rivets you need here:
      http://www.trimtags.com/rivets.html
      Jun 2006
      NW burbs IL
      Quote Originally Posted by SimplyKC
      Unless some moron tranfers that number to the title at some point. That is the situation I had when I bought my car, thank God I was able to fix it when I titled the car in IL. By the way my trim tag was removed from the car but in my possesion. Then I just explained to the officer what all the numbers meant, he did a search on the actual vin which did not come up in any database, and was told to fill out the paperwork with whatever number I wanted. I settled for the correct vin number.
      Matt
