    Results 1 to 9 of 9
      Feb 2006
      Noise at low RPM, goes away at off-idle
      A problem just crept up and it has me stumped. I just finished installing a stereo system and I finished installing my interior. During this time I also upgraded to H4 headlights. I was anxious to get out at night and test the lights out. Everything worked fine and the car was running great. The next afternoon I intended to calibrate my electronic speedometer. I started the car and I hear a rumbling sound from the engine. It’s hard to describe, but it sounds like something came loose and is rattling around hitting something that is rotating. It is very loud so it’s hard to tell exactly where it is coming from, but it sounds like it is coming from the torque converter. My first thought was that the starter did not retract all the way. The weird thing is, my car idles at around 900 rpm in park, if I rev the engine to about 1100 rpm the noise vanishes and the engine runs smooth. I took the car out for a drive and it is shifting well (700R4 trans) and there is seemingly no loss of torque (still bangs through gears and I can light up the tires easily).
      So, I check all the fluid levels: all fine. I put the car up on jacks and start it. It still sounds like it is coming from the torque converter. I look at the gap between the flex plate and the starter gear and it’s real close. When the engine is stopped I have about 1/4” gap, but when running that gaps closes up. I have a lot of play in the flex plate. I first check the bolts from the flex plate to the TC, all tight. I can’t check the flex plate to the crank bolting, but the flex plate seems tight. So back to the starter, I shim the motor away from the flex plate a bit more than 1/8”. I was sure this was going to fix it, but it didn’t. So now I am stumped! What can all of a sudden come loose and only make racket at low RPMs, sound like it coming from the TC or at least from underneath the car, and not cause any noticeable performance loss!? Any help will be greatly appreciated.
      By the way, the engine is a new crate 350 that I installed this winter. The transmission is also new and was installed last fall.
