    Results 1 to 10 of 10
      Jan 2007
      Paint for master cylinder??
      Is there any paint out there that will stand up to brake fluid? I want to paint the exterior of my master cylinder and want something that will stay on.
      Auburn, WA
      There isn't much, but I use Polane from Sherwin Williams for anything that might come in contact with brake fluid (firewalls, etc). Only comes in black and stinks like heck. I've had a few spills that sat for quite a while and didn't even cause a blemish.
      You have to buy it at Sherwin Williams Industrial Coatings, BTW, not a standard SW store.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Harriman, Tennessee
      I have had good luck with POR15, sliver. My dad, on the other hand, hasn't, but I swear his master cylinder is pourus.
      Shiny Side Up!
      Bill
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Apr 2004
      OKC, OK
      Use a synthetic brake fluid and it is less like paint stripper. Then most paints should stand up to it.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Rancho Palos Verdes, CA
      What are the drawbacks of synthetic brake fluid?
      TOURS/SS
      Apr 2004
      OKC, OK
      None that I know of except maybe cost. Synthetic brake fluid has a higher boiling point than DOT 3 as well
      mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      NY
      Use a spray bottle full of soapy water. Spray down the surrounding areas and be very carefull. You could also disassemble and powdercoat if your guy is good.
      I think Valvoline??makes a synthetic blend that is not as caustic.
      Feb 2003
      Houston, TX
      I'd avoid Valvoline synthetic. Several of us tried it in our C6 Corvette clutch hyd systems and they boil faster than regular DOT non-synthetic fluids, causing the clutch pedal to stick to the floor. The Prestone synthetic works much better.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Jan 2007
      flushing dot 3
      What would one use to flush the dot 3 out?
      England
      What about brake caliper paint
