    Results 1 to 14 of 14
      florida
      Removing a broken bolt
      I have a broken bolt on the bottom of my 69 Camaro where the fender bolts to the body underneath close to the firewall area. I have about 1/4 of the bolt sticking out and it is rounded out bad. I have tried to heat it up and use vice grips, pipe wrench and everything else. Does anyone have a better way then drilling it out with several bits? Thanks in advance..
      Miami
      do you got a welder? If so weld a new bolt to the existing one. Let cool and try and back the bolt out...
      Aug 2006
      Hampton Roads, VA
      You could try soaking it thoroughly with Liquid Wrench or WD40, then take a chisel and hammer and make an indentation on the bolt. Then try tapping it with the hammer and chisel counterclockwise to see if it will turn. If you can get it turned out a few turns this way, you might be able to get a vise grips on it and take it the rest of the way out.
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      California
      weld a nut to it in the threaded area, then use a socket and remove. and try soaking it with a penatration oil
      Florida
      If you're removing the fender use a cut off tool to cut the head off of the bolt then deal with it after the fenders off
      Nov 2001
      Sacramento Ca
      use a flame to heat the bolt then apply candle wax. the heat will suck the wax down the threads and lube the bolt up.
      Its broken loose stuff I thought would never come off.
      Tony Langlois
      1966 Corvair Monza
      north central Iowa
      Quote Originally Posted by NOT A TA
      what he said because it probably goes into a speednut and wont be too hard to deal with once the fender is out of the way.
      north central Iowa
      Quote Originally Posted by TonyL
      i'll have to remember that trick
      florida
      The fender is already off, I will try the wax trick, it will have to suck the wax up because the bolt faces down but hey what do i have to lose?
      California Bay Area
      Wax works great it lubes the threads,But with the bolt going down that will be tricky
      65 Impala
      01 Z06
      Garwin, Iowa
      smack the broken bolt on the end a couple times to try to stretch the threads a little, then weld a nut to the end of the broken/stripped bolt and remove with a ratchet. You might go through a few nuts before you get one to bite, but usually works.
      Feb 2002
      Springfield, MO
      Weld a nut to it, works great. Or those bolt removers from Craftsman work awesome also! The more you twist it, the tighter it gets.
      Wax works good, keeps things nice and tidy, but it hurts when you pull it off!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      florida
      Where do i get the Craftsmand bol;t remover? I dont have a welder....
      Northwestern NJ
      X2.
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
