      San Antonio, Tx
      smoothing stock sub frame
      i want to make my subframe on my camaro smooth like the DSE demo parts car :icon996: , does anyone know how they did it? i know lots of grinding and such but how about the difference in hight of the over lapping frame half?
      Instagram: CamaroAJ
      Ortonville, Michigan
      I think on the lower side of the frame half you would have to weld in another strip of metal to bring it up to the height of the other side. Hope this helps
      Billy
      San Antonio, Tx
      thats what i was thinking but not for sure, what about welding a piece of 16g sheet metal to it. that way i don't make it a total pig with all that extra steel on it. how do you guys feel about somekind of body filler on the frame just for pin hole spots that sanding the frame down can't get rid of?
      Instagram: CamaroAJ
      Mar 2003
      Boringville
      how about bondo?
      Henderson, NV
      DONT BONDO IT UP! I guarentee it will crack if layed on thick. I've seen it happen. Pin holes and depressions are ok as you had stated. Adding the 16ga should work good. Lots of grinding and sanding and smoothing.
      Shane Wagner
      1970 Chevelle "Cholula"
      2010 Camaro "Proven1"
      Mar 2003
      Boringville
      forget adding all that metal. Extra weight, tons of extra work, just grind the welds smooth and call it a day. A skim coat of bondo could cover up some of the work. I personally wouldn't put bondo on it, or grind the welds. I think powdercoating works great and looks good. You can call DSE I am sure they would be very willing to tell you what they did
      San Jose, CA
      Tons of hours were spent welding plates on the frame and a liberal amount of filler was used. That frame is AWESOME, but is inteded for display purposes and it's not ever going to be used on the street.
      Tony Huntimer
      RaceHome.com
