    Results 1 to 20 of 23
      DFW
      New to Forums + 71 Firebird LS1 swap
      hows everyone doing? after looking at some peoples cool projects, i thought i would share mine. i bought a rust-free 71 firebird with a formula hood (not original) and an 01 TA with a rear quarter hit. overall, i plan on putting the 01 dash, seats, and interior into the 71 as well as the LS1 and tranny.
      so far, the the 71 wheel tubes have been extended and the rear frame has been shaved to fit the 17" torque thrust IIs and 315mm rubber. the four point roll cage has also been put in. i already bought 12.5" drilled and slotted 3-piece rotors, aluminum hub, 4-piston calipers all around, 2" custom drop spindles, QA1 conversion coil-over springs and 12-way adjustable shocks. the drive-shaft tunnel had to be cut and moved over to fit the panhard bar and the rearend will be held in by the underslung bars from the frame. also bought a 77 tail light pannel to be welded in and have the older style tail lights. the door handles have been shaved, the side markers, and the rear hood vents have also been deleted.
      the total height of the car will be 51" off the ground with almost and inch of rake. i'm also looking at a house of kolor blue to paint it. there's a whole lot more that will be done, but it's smaller stuff. the fine details... i can't wait until it's done! hopefully if everything goes well, it should be done by late this spring or early summer, and definitely have it show in the hot rod power tour over in milwaukee, wisconsin.
      i was also curious if anyone else has done some modifications like these to second gen firebird? i bet the camero is pretty similar. i've got plenty of questions of course. i noticed that a fellow newbie, raptor pilot has a 70 firebird. what all are you doing to your bird, raptor? anyways, i have more and larger pictures if anyone is interested.
