    Results 1 to 20 of 28
    Thread: Abs!
      California
      Abs!
      I've always wanted to try and implement ABS into my car, and I figure since I plan on getting the ATS spindles, it's the perfect opportunity. So basically, what would I need to do to get it working? Whenever I get the money, I'm going to get the spindles (obviously) and the 12.7" Touring Classics C5 brakes all from ATS.
      Matt
      Dec 2002
      Lost Wages, Nevada
      You will need to steal or beat the EBCM algorithms out of BOSCH...
      You will also need to install wheel speed sensors on the rear axle that have the same resolution of the front wheel speed sensors.
      Next, you will need the pump and accumulator, the motor and controller and the EBCM... and depending on what year of ABS controller you run... the BCM.
      That will be all well and good right up to the point of needing the algorithm modifications for your chassis and wheel, weight and balance. If you have a friend at BOSCH... I suggest you put the screws to him.
      California
      There has to be an easier way. I remember reading a few articles in magazines where people put abs on their cars.
      That just ruined my day. :(
      Matt
      Dec 2002
      Lost Wages, Nevada
      The mechanics are simple... the algorithms however, are not really test and tune. You have to pretty much adbide by the same PV ratios used in the system the controller came from. Meaning that you have to run the same lines size, the same master, the same caliper volume etc etc. The individual dynamics of wheel and tire, wheel base, weight distro and rotational weight differences are just attributes to the algorithms.
      The articles in magazines are from like vehicles and not having too many years between donor and recipient. The Camaro (BOSCH 8.x) on the last years will require you to add reluctors to the axle shafts and then some simple brackets for the exciter. The only problem with that is the sensor is a little different in how it works (yes the end result is the same in theroy) but the resolution is somewhat different.
      So the only way to really make the system work is to use the same Y-body wheel speed sensor in the rear. Which means adapting the bearing cartridge to the housing... which I have done, Im just waiting for a few other parts to get the housing completed. Now its just getting to the electronics.
      You have your choice in using the two available Y-body units. Both are BOSCH 8.x and were made to work with the given sensors. Out of the three systems (97-98 / 99-04 / 05-07), one uses less inputs (97-98)... and will be eaiser to work with. You will however, loose the traction control (unless you run an LSx and ECU along with the BCM) and active controls... due to not using the yaw rate sensor. This by far will be the easiest to integrate. I will advise you to purchase the factory GM service body and drivetrain manuals as this will pretty much spell it out for you mechanically and electrically... just not algorithmically.
      And that is where this project becomes a little more difficult. I will not discourage you from your efforts... infact, I say go for it. If I can help in any way let me know... I will share what I have, including the frustration with BOSCH and their proprietary algorithms and the fact that they wont go open source for the aftermarket.
      There was an ABS kit you could buy. It wasnt electronic though. It was 2 Bulbus things that mounted inline with your front and rear lines. Not sure how they worked but it obviuosly didnt catch on.
      I think they just smoothed out pressure spikes like if you tryed to dynamite the brakes they would take the spike out and the pressure would apply over a longer controled time. Spring and piston inside maybe??
      pittsboro, nc
      there's always a complete vette rolling chasis on ebay. they usually include the brakes as well. buy youself a chasis & wrap a body around it. you might could even install a heads-up-display.
      68 camaro ls1 restomod
      Nov 2004
      Colorado
      Quote Originally Posted by chicane67
      What exactly do you mean by resolution? Are you talking about tooth count on the reluctor wheel? Just what is the difference between the late 4th gen front sensor and the c5 sensor?
      Aug 2005
      Hamilton, NJ
      I did read one article in one of the rags some years back. IIRC, a guy took an ABS setup out of a late model Caprice and put it in an early 80s Caprice. I don’t remember the details anymore, but I remember the owner’s comment: it worked, but it was not worth the effort.
      Scott from NJ.
      Vent Windows Forever! ...
      England
      What does the ABS work on , foot on brake as long as sensor sees the wheel moving does not kick pressure off pad wheel stops foot still on brake kicks pressure off pad, why would you need weight of car as long as its close to donor car due how would car know if you had 1 ,2,4,5 people in car and fully loaded with cases etc, wheel dia I think would not come into it, look at all with modified wheels ie bigger on cars with ABS.
      Nov 2004
      Colorado
      Quote Originally Posted by paul67
      I have made this argument. I think the vehicle stability functions are getting confused witht the ABS functions.
      Each channel is monitored separately for spin during a braking event, if the wheel locks, pressure is modulated to induce spin.
      The only time speed differentials between front and rear would matter would be in a traction control system where slip would be a difference in the front and rear sensors, but then again they might do it by looking for an improbable increase in speed.
      Fontana, CA
      Wheel diameter and weight do come into it. Test the brakes on a Silverado or other with stock 16" rims. Then step up to 20s or larger and notice that the ABS kicks in sooner with the larger rims. This was noticed by CHP when they had the Big Red or Red Dog truck build up a year or so ago. It has also been noticed by my friends and I. It is not terrible, but noticable under heavy braking that the ABS does kick in sooner.
      Nick R.
      Oct 2005
      Long Island NY
      My buddy with the AMX that was in real street elimator last year has had ABS on his car for at least 10 yrs..Talk about ahead of his time. Mostly GM stuff if I remember.
      Peter Bergman
      71 Dart GT, Stroker SB, Built For The Turns!
      California
      Yeah, I remember reading about someone implementing it onto a first gen Camaro a few years ago. It's definitely something I plan to do, but I have more pressing issues to deal with on the car, so this will probably be a long way off.
      Thanks for all the info though guys. And Chicane, don't be surprised if you get a pm from me in a few months or so. :p
      Matt
      Rochester, NY
      May I ask why? Is it for the use of the abs or just to technological coolness of installing it? Either one is a valid reason I'm just curious. My 87 Mercedes s-class had the best abs I have ever experienced. I don't think there was much, if any, computer control. On the other hand my dad's daily driver 2002 Grand Am just has annoying abs. In fact a wheel speed sensor went south about a year ago disabling the traction control and abs, turned out to be quite the upgrade. In my opinion abs is most useful in the winter and no PT car deserves that kind of punishment. If your desire is just to see if you can do it, however, then by all means go for it.
      Nov 2004
      Colorado
      Quote Originally Posted by matthimself456
      For me you hit the nail on the head. Its the mostly the challenge of installing it and making it work.
      Dec 2002
      Lost Wages, Nevada
      Quote Originally Posted by EFI69Cam
      1. What exactly do you mean by resolution?
      2. Are you talking about tooth count on the reluctor wheel?
      3. Just what is the difference between the late 4th gen front sensor and the c5 sensor?
      Seriously... do we have to hash this out again ??
      1. The degree of accuracy within a given bandwidth without inducing adverse effects.
      2. No
      3. A finite resloution bandwidth, which is less effected by voltage saturation on the upper end of the bandwidth.
      ...why would you need weight of car as long as its close to donor car due how would car know if you had 1 ,2,4,5 people in car and fully loaded with cases etc, wheel dia I think would not come into it, look at all with modified wheels ie bigger on cars with ABS.
      It effects bias and proportioning. Afterall it is the resultant function of weight transfer. Wheel diameter and any change to the packaged weight (rotational mass/inertia) has a larger effect to system operation. A good explaination/observation was noted in an earlier post.
      Trust me... if it were as easy as all of you make it out to be... there would be groves of older chassis with ABS. But... as we can plainly see there isnt. Sure I could throw some parts together and have a working system. But does that make it right? Does it make it safe? Maybe what most have not thought about yet is the liability behind the implimentation of a system not verified or tested for the application. I am sure Federal DOT would have some creative things to say about it. Repercussions are a bitch.
      Afterall, if its worth doing... its worth doing right.
      California
      Definitely the use. I live in Southern California, and we don't really have winters, so I drive my car year round.
      Basically, I want this thing to stop the best that it possibly can. I plan on getting a Hydratech system, some 13" brakes up front, probably 12's out back, 245-255 front tires and 275-285 rears, and *hopefully* abs if I get to a point where I have nothing better to do. :p
      Matt
      Southern Indiana
      Ok so basicly the fronts (with ATS spindles)are going to use hub bearings similar to vettes or ZQ Blazers right?
      If so then you have the sensors on front. If you have a locker or a limited slip in back then you would want the type that reads off the ring gear for a pro touring(I figured this out as we put an LSD in a car with ABS and had to find a computer that came from factory LSD equiped car.
      The pumps/modualtors I would use from say a lager body GM that is divorced from the master cylinder(ie parts matching,,, now you got me scratching my head and digging in catalogues) and thn it would simply be a matter of decrypting the EBCM from the car the pump/modulator is from and making it understand what you are working on.
      Actually I may try something like this on my Monza hehe as I thing the 98 up ZQ Blazer has this type of differentail sooooo,,,,, hehehe Wuahahahahahahahahahahahahaa. Evil grin, Evil laugh.
      Lee
      Nov 2004
      Colorado
      Quote Originally Posted by MonzaRacer
      Lee
      Nooo what ever you do don't try this! It won't work and your car will literaly fly backwards when you apply the brakes.
      California
      Huh???
      Matt
