Results 1 to 20 of 21
Thread: Fuel presssure drop
03-31-2007 #1
Fuel presssure drop
I have a 1969 Camaro with all new tank, lines, motor, pump, and carb.
The car ran fine (100 miles) until recently.
Now it will start fine with 7 psi fuel pressure. After a 10 minute drive the car will start to die and have fuel pressure between 0-3 psi.
I tried swapping pumps and it still does it. The pump I swapped was used and I assumed it was good, but it may not be.
I removed the line from the tank to pump and notices that fuel trickled out (not poured).
I removed the tank to ensure that the "sock" was clean and there were no obstructions. There were non as everything is new.
I put my finger over the inlet hose from the pump. Should there be suction? There was none.
Any suggestions?
03-31-2007 #2
What kind of pump, and where is it mounted?
