    Results 1 to 3 of 3
      Eastern Virginia
      I need AN fittings on an LT1 power steering pump
      How do I connect AN hoses to an LT1 power steering pump?
      Scot
      86 Monte SS
      Jacksonville, FL
      AN fitting
      I believe you need a 16 mm o-ring to AN6 (if you are using a size 6 line) fitting, if you are talkijng about the high pressure line on the pump. Call Paul at Hydratech, he knows all about the correct size info.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Eastern Virginia
      Initially I was thinking the hose I needed it for was a slip on connection. Dummy me, that is the high pressure side & has a screw on connection. Won't be as tough as I thought. Does the outlet of the reservoir need to be higher than the inlet of the pump? Or just the fluid level higher than the inlet? If the outlet of reservoir needs to be higher, I may have a tough time finding a place to mount it.
      Scot
      86 Monte SS
