Thread: Do you think this will work?
As mentioned in one of my prior posts, I have installed a 9" rear in my 69, but the guy who built the rear-end left the companion flange yoke in it. So, originally I was going to replace the yoke with a more typical 1330 or whatever, and then do what is necessary to get the driveshaft to mate up.
However, I was sniffing around Currie's site and I found this item:
http://www.currieenterprises.com/ces...e.aspx?id=1043
It's a companion flange adapter, that mounts to my big round companion flange and allows the driveshaft and u-joint I currently have to still work. Does anyone see any problems with doing it this way? Am I really taking the easy way out at the expense of performance/reliability?
Thanks guys
Jeff K.
69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
03-28-2007 #2Ugh, nevermind guys, I just got a call back from Currie and they say it won't fit the old style companion flange I have. So nevermind that, guess I'll have to go the expensive route on this one and replace the yoke.
Jeff K.
03-28-2007 #3If you can get the other half of the companion flange that is on your 9 inch the you can use it. They just take a comon u joint.
'69 RS/SS396 pro street/427/4spd/9"
http://rides.webshots.com/album/576443881hfGXxd
http://good-times.webshots.com/album/568860081GZRpyZ
04-01-2007 #4I ended up having a new driveshaft built with the end that matches up with the companion flange yoke on my 9". The guys at D_ick's driveshaft in Phoenix had it built in a couple hours and now that it's installed I'm glad I went that direction. The companion flange assembly looks like it would be quite strong, but I'm no engineer so who knows.
Thanks for all your input,
JKJeff K.
