    Results 1 to 11 of 11
      Scottsdale AZ
      Off idle stumble/pop
      I have a 383 approximately 475 hp with a Comp Cams 288 roller.
      The car has a new Holley 750 hp and a new Flame Thrower HEI.
      I have the initial timing set at 15 degrees witha total 35 degrees.
      when a rap the throttle from an idleI get a slight stumble and sometimes a backfire through the carb (like a lean pop). I installed larger squirters and cam in my previous 750 and that did not seem to help. I then bought the 750 dp as I thought I neeeded more fuel.
      The "pop: is not as bad with more timing. I have been playing around with the vacume advance (adjustable kind) but it does not seem to remedy the proble.
      Any suggestions?
